Can VG224 have both SCCP and H.323 running at the same time?
May 13th, 2007
Hi, there,
Can VG224 have both SCCP and H.323 running at the same time? If yes, how to configure? Please help.
Overall Rating: 0 (1 ratings)
irisrios Mon, 05/21/2007 - 06:06
TheCallManager sees the VG224 devices like any other phone, so the conferencing should be no different than the other phones. They need to be assigned to a Device Pool that has a Media Resource Group List with the correct Conference Bridge settings. However, you cannot use a VG224 as a conference bridge.
ivarnhagen Fri, 01/21/2011 - 04:01
I would also like an answer to this question.
The reason: we have analog phones connected to the VG224, as well as modems. Other IP Phones need to have the analog phone lines displayed as BLFs (SCCP). H.323 is recommended for modems as they don't seem to work well with SCCP.
Has anybody configured this? If yes, then how? I would appreciate any feedback.
Paolo Bevilacqua Fri, 01/21/2011 - 11:55
Just configure the ports you need as SCCP, with application stcapp. Other ports will be used by pots dial-peer.
