Push2phone on 7921G
May 14th, 2007
I'm wondering if anybody has got the new 7921G phone to work with push2phone -application? We have currently that application working with 7920's but now with the 7921, the phone displays "Authorization Required!", and nothing else happens. I guess there might be some big differences, because 7920 uses VxWorks as the operating system, and 7921 uses Linux...
TIA,
Sami
stephan.steiner Mon, 05/14/2007 - 23:23
  • Silver, 250 points or more
So what happens if you send the authentication? Do you see the phone making a request to the authentication url (see as in a wireshark trace)? and what is the phone's answer for the POST request? Does the request time out or is there an answer to sending the credentials?
stahkaoja Sun, 05/20/2007 - 22:35
Well, the wireshark trace shows the following for the 7921: 4898 > http [RST, ACK] Drw=620 Ack=360, Win=0, Len=0 HTTP/1.1 401 Unauthorized
I did the wireshark trace also for 7920, and it says http > 1170 [ACK] Seq=339 Ack=578 win=64959 Len=0 HTTP/1.1 200 OK. Other than that, I don't see any notable differences.
The error message "Authorization Required!" displays at the same moment in the phones screen, when I push the "Send" button in my application.
stahkaoja Wed, 06/20/2007 - 03:26
Just figured it out... I simply had forgotten to associate the 7921-phones with the "sdkapps" user that I have.
But now I have another problem; We have upgraded our CCM from version 4.0 to 4.1(3). And the pushing doesn't work anymore.
By reading this forum, I have understood that the change from http -> https is an issue here. Mainly, the problem is with the file 'getdeviceip.asp' The line 'return ipAddress;' causes a problem. If I hardcode it to like 'return "192.168.0.100"', then it works for that IP-address. But I didn't find any solution how to change that file so that it works with https properly...
