ankbhasi Mon, 05/14/2007 - 02:38
  • Cisco Employee,
Hi Upendra,
Your question was not very clear. Do you want to shut down multiple interface with one command? If thats what you want you can use range command something like this
config t
interface range fa0/1 - 10
shut
remember to use "space" between 1 "space" -"space"10.
Ankur
*Pls rate all helpfull post
upendra07 Mon, 05/14/2007 - 03:05
dear
I want to know can give multi vlan access on switchport.i have one port is not use second is used how can i use this command.
ankbhasi Mon, 05/14/2007 - 03:09
  • Cisco Employee,
Hi Upendra,
I believe you want to have one port to ba a prt of multiple vlans? Is that correct?
If yes you can configure trunk port and allow all vlans which you want that interface to ba a part of.
Something like this
swithport mode trunk
In all new switches and IOS other than trunk configuration there is no way you can assign single interface with multiple vlans.
Ankur
Manish Prasad Mon, 05/14/2007 - 03:28
yes you can do this. make this as a trunk port. and this port will carry all vlan information and can be member of any vlan
