VACL puzzle on Cat6500 IOS
May 14th, 2007
I have to capture traffic and I wish to apply the VACL Capture as described in the doc "VACL Capture for Granular Traffic Analysis with Cisco Catalyst 6000/6500 Running Cisco IOS Software"
(http://www.cisco.com/en/US/partner/tech/tk389/tk689/technologies_configuration_example09186a00808122ac.shtml):
1. Define the interesting traffic.
Cat6K-IOS(config)#ip access-list extended HTTP_UDP_TRAFFIC
2. Define the VLAN access map.
Cat6K-IOS(config)#vlan access-map HTTP_UDP_MAP 10
Cat6K-IOS(config-access-map)#match ip address HTTP_UDP_TRAFFIC
Cat6K-IOS(config-access-map)#action forward capture
3. Apply the VLAN access map to the appropriate VLANs.
Cat6K-IOS(config)#vlan filter HTTP_UDP_MAP vlan-list 10
4. Configure the Capture Port
I am wondering that if I apply that "vlan filter", the 6500 will discard all the traffic that does not match the ACL, as sketched in the IOS 12.2(SX) conf. guide (3rd example):
(http://www.cisco.com/en/US/partner/products/hw/switches/ps708/products_configuration_guide_chapter09186a0080160a7e.html#wp1055968).
The question is: to capture only the matched part of IP traffic without to discard the unmatched traffic, must I end the access-map with a default "action forward"?
Best regards. Paolo Calcaterra
