3750 Switch Stack - Remove member from stack
Answered Question
May 14th, 2007
I'm new to using the 3750 switches and am trying to understand all of the necessary steps to completely remove a member from the stack. The current stack only consists of two switches and I need to remove one (which happens to be the slave)... leaving the other to run solo permanently.
From what I understand, the steps would go like this...
1.) Remove power from switch to be removed
2.) Issue command "no switch 2 provision ws-c3750-48p"
3.) Issue command "copy run start"
Done.
I would expect this to enable me to remove the switch and also removes all reference to the removed switch from the config.
Did I miss anything here?
Thanks!
-Adam
Overall Rating: 3 (1 ratings)
a.veschak Mon, 05/21/2007 - 11:03
Phillip,
Thanks for the reply.
I've seen the link you provided before... I just wanted to make sure I wasn't missing anything... seemed a little to simple, but I guess that's all there is!
-Adam
