spremkumar Mon, 05/14/2007 - 19:08
Hi Brad
Are you talking about disabling and reconfiguring the ssh service then you can enable telnet or use console to disable the SSH service and reconfigure accordingly as per your requirement..
Make sure that you are disabling telnet back once you are done with enabling SSH service.
regds
Correct Answer
Danilo Dy Tue, 05/15/2007 - 04:13
Hmm, you mean restarting the service like how we do it in the UNIX/Windows?
I don't think you can do that in IOS/CATOS
