802.1x issue
May 14th, 2007
I have configure my switch with this:
#aaa authentication dot1x default group radius
#dot1x system-auth-control
#radius-server host 214.3.80.7 auth-port 1645 acct-port 1646 key 7 0601592D6C40
I have everything configured and I am using cisco secure ACS as the Radius server and my DC as the CA. The laptop I am trying to authenticate already has a certificate that was issued by the CA.
when I debug 802.1x I recieve this message:
2w1d: @@@ dot1x_auth_bend Gi0: auth_bend_idle -> auth_bend_request
2w1d: dot1x-sm:Gi0/5:0000.0000.0000:auth_bend_request_enter called
2w1d: dot1x-packet:dot1x_mgr_send_eapol :EAP code: 0x1 id: 0x2 length: 0x0005
type: 0x1 data:
2w1d: dot1x-ev:GigabitEthernet0/5:Sending EAPOL packet to group PAE address
2w1d: dot1x-ev:dot1x_mgr_pre_process_eapol_pak: Role determination not required
on GigabitEthernet0/5.
2w1d: dot1x-registry:registry:dot1x_ether_macaddr called
2w1d: dot1x-ev:dot1x_mgr_send_eapol: Sending out EAPOL packet on GigabitEthernet
0/5
2w1d: EAPOL pak dump Tx
2w1d: EAPOL Version: 0x2 type: 0x0 length: 0x0005
2w1d: EAP code: 0x1 id: 0x2 length: 0x0005 type: 0x1
2w1d: dot1x-packet:dot1x_txReq: EAPOL packet sent out for the default authentica
tor
2w1d: dot1x-sm:Gi0/5:0000.0000.0000:auth_bend_idle_request_action called
2w1d: %LINK-3-UPDOWN: Interface GigabitEthernet0/5, changed state to up
2w1d: dot1x-packet:Received an EAP request packet from EAP for mac 0000.0000.000
2w1d: dot1x-sm:Posting EAP_REQ on Client=2EE6D38
2w1d: dot1x_auth_bend Gi0: during state auth_bend_request, got event 7(eapRe
q)
2w1d: @@@ dot1x_auth_bend Gi0: auth_bend_request -> auth_bend_request
2w1d: dot1x-sm:Gi0/5:0000.0000.0000:auth_bend_request_request_action called
type: 0x1 data:
0/5
tor
and it repeats itself so I think it has something to do with the server I am running the RADIUS. Is it the ACS certification Setup? or something else ? can anyone help me with this?
beth-martin Mon, 05/21/2007 - 06:07
  • Bronze, 100 points or more
Kindly check the status of the radius server by issuing the command " show aaa server".
in the output see whether the staus is flapping between up and down
natenephew Mon, 05/21/2007 - 06:34
I'm having virtually the same problem. When I do 'show aaa server' the server seems to be UP continuously. Have you come across any possible solutions?
