maximum IOS in Cat 6500 w/ Sup 32
May 14th, 2007
Hi Guys,
Any one who knows where I can find a documentation where it says the maximum images of IOS in flash of the Cat 6500 Series with Supervisor 32.
Marcos
Overall Rating: 3 (2 ratings)
Danilo Dy Tue, 05/08/2007 - 14:57
  • Blue, 1500 points or more
Sup32 info
1. DRAM
- 512 MB DRAM comes by default on the Sup32 for both the base board and MSFC2A, and both are field upgradeable to 1 GB
2. FLASH
- 256 MB is default size of the internal compact flash and is not field upgradeable.
- External compact flash is optional on Sup32. The compact flash supported at FCS are: MEM-C6K-CPTFL64M, MEM-C6K-CPTFL128M, and MEM-C6K-CPTFL256M
Well, with the maximum DRAM and FLASH that the Sup32 Supported, there is no current IOS that will exceed that requirement - even half of it.
http://www.cisco.com/en/US/products/hw/switches/ps708/products_qanda_item0900aecd801ff38a.shtml
Dandy
e-dennington Mon, 05/14/2007 - 06:23
You can have as many as you want, but flash memory is limited to 256MB for on-board flash. I'm not sure if there is a size limit for the size of flash cards that the Sup32 supports.
marcos.marques Mon, 05/14/2007 - 06:32
Have a document it says that? I need a document shows this information but not find.
