2691 Router Error
May 14th, 2007
Hello -
Could anyone please tell me why this happens everytime I do a 'wr mem' on a C2691 router with 32MB flash. Running 12.3(5d) code.
*Mar 1 00:04:41.811: %SYS-5-CONFIG_I: Configured from console by console
% Warning: Saving this config to nvram may corrupt any network management or sec
urity files stored at the end of nvram.
Continue? [no]: y
%SYS-4-CONFIG_NV_OVERRUN: Non config data present at the end of nvram is corrupted[OK]
ankbhasi Mon, 05/14/2007 - 08:31
  • Cisco Employee,
Hi George,
Can you please try the following?
Router#config t
Router(config)#service compress-config
Router(config)#exit
Router#wr mem
Let me know if this works.
Ankur
*Pls rate all helpfull post
Richard Burts Mon, 05/14/2007 - 08:47
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
Ankur
I have had some routers with that symptom and in my experience it was not an issue with config file size (and if there is an issue with config file size I believe that the error message is different). So I am not optimistic that service compress-config will change these symptoms.
I believe that there are a couple versions of IOS that exibit this behavior. When confronted with this message I have saved the config anyway and have never had problems where the router found anything corrupted that pervented its functioning.
I believe that the best way to deal with this problem is to upgrade to a newer version of code (that is what I did to make the error message stop - and I found it quite effective).
Rick
smothuku Mon, 05/14/2007 - 21:07
  • Silver, 250 points or more
Hi George ,
Meaning of the error messages is as below.
The software detected that the configuration saved into NVRAM has overlaid a part of the NVRAM that is occupied by nonconfiguration data files. Typically, these files are used by SNMP to store and retrieve nonconfiguration persistent data across a system reload.
Recommended Action: Compress the configuration, and copy to Flash memory.
Related documents- No specific documents apply to this error message.
Satish
