Unity Installation
May 14th, 2007
i am installing Unity 4.2.1 and i am having serious issues with the permissions wizard. When I go to choose a mailstore, i get a message teling me it could not find any windows 2000 mailstore. I am fllowing the Unity install PDf and have installed Exchange 2000. When i look under the System Managemnet in Exchange, I do not see the server option. Has anybody come accross this before and if so, have you got a workaround?
mchandak Mon, 05/14/2007 - 07:14
Is Exchange installed on the same server as Unity or on a remote server ?? Where are you running System Management tool from. From my past Experience, most common cause of this issue would be an installation error with Exchange.
mchandak Mon, 05/14/2007 - 08:01
Couple of things you can check here to confirm Exchange was installed correct.
- Do you see an M Driver on the server ?
- When you go to Active Directory Users and Computers, for a User, right click and select Exchange Tasks. Does this give you an option to Add/Delete a Mailbox for the user ??
And also ensure that Unity Install accounts have the right permissions before running Permission Wizard.
mrugeshpatel_2 Wed, 08/01/2007 - 08:55
during your exchange install, did you select microsoft exchange messaging and collabration? I think this is your problem
