Layer 2 connectivity from Reading to London
May 14th, 2007
I have a 4006 Cisco IOS and have configured a port
as a 100 meg trunk
interface FastEthernet3/48
switchport mode trunk
duplex full
speed 100
ACN_CS_1#show vtp status
VTP Version : 2
Configuration Revision : 1
Maximum VLANs supported locally : 1005
Number of existing VLANs : 17
VTP Operating Mode : Server
VTP Domain Name : mcaa
I have vlan 1 enabled.
on the 4006 Catos i have configured
set vtp domain mcca
set vtp mode client set 2/40 on dot1q
Catos is running VTP mode 1
I can see the switches via vtp but no vlans are propergating and im unable to ping
mohammedmahmoud Mon, 05/14/2007 - 10:28
VTP version1 and VTP version2 are not interoperable on network devices in the same VTP domain. Every network device in the VTP domain must use the same VTP version. Do not enable VTP version2 unless every network device in the VTP domain supports version2, accordingly your solution is to configure both to run Version 1.
HTH, please do rate all helpful replies,
Mohammed Mahmoud.
