Lost ringtone setting after a power outage and reboot
May 14th, 2007
I am having this issue. We scheduled a power shutdown over the weekend and shutdown the whole cluster except 1 sub. FYI, the TFTP is on pub and was shutdown. After we got the power back, we turned back on the whole cluster.
Now, users are complaining that their ringtone setting is gone. I tested it this morning while all the servers are up, and I unplugged the phone. When I plugged the phone back, the ringtone setting stays.
So, how the ringtone setting gets lost?
Thx
jason-calbert_2 Mon, 05/14/2007 - 08:40
  • Bronze, 100 points or more
If you look at one of the phones that does not have the ring tones does the TFTP address appear correct under settings -> Network Configurations?
The order in which you brough up your callmanagers may have made a difference also. Perhaps if the phones registered with subscribers before the PUB(TFTP) came up then they would not of been able to contact TFTP at that time.
Jason
bluejays Tue, 05/15/2007 - 09:28
Now I am having another problem....
Under the ring type setting for the phone, only the default shows all 24 ringtones, but the any particular line, it only shows 7 ringtones. I checked the TFTP server, there are 2 files, RingList.xml and DisctiveRingList.xml. The first one has all 24 ringtones but the 2nd file only shows 7 ringtones. So I copied the 1st file content over to 2nd file. I erased/reset the phone and it still shows 7 ringtone for a particular line but 24 ringtones for the default.
Can I have 24 ringtones for a particular line?
bluejays Tue, 05/15/2007 - 09:56
Never mind the 2nd question. Figure it out. Restart TFTP does the trick.
