PIX 515e Memory Full - Connectivity Stops
Answered Question
May 14th, 2007
PIX 515e w/ 7.2(2) and 64 MB memory. On cold boot, memory usage is about 42 MB. No significant logging; buffer set at 1000. Over a couple of weeks or so, memory usage continues to grow until full at which time the unit stops passing some traffic, e.g. smtp. Only a cold boot cures the problem. I am at a loss trying to figure this out.
Correct Answer by srue about 9 years 5 months ago
possible bug.
got smartnet?
Overall Rating: 5 (1 ratings)
cpembleton Mon, 05/14/2007 - 09:29
Do you have a restricted, un-restricted, or Fail over license?
If you have un-restricted or fail over you don't have enough memory to run 7.X.
ynyng Thu, 05/17/2007 - 09:23
Thank you srue. This looks like the issue. Should be reolved by upgrade to 7.2.2(19)
