2960 or CE500 are better for Traffic carrying video over IP
May 14th, 2007
I have a small Lan with fiber backbone. It carries Video over IP together with the Data traffic. Which switch performs better with this heavy traffic WS-2960 or WS-CE500
paolo bevilacqua Mon, 05/14/2007 - 08:32
  • Hall of Fame,
    Founding Member
I think both switch perform the same, but most people doesn't like the 500 because it not true IOS without a CLI and the advanced feature you may need.
sa182802 Mon, 05/14/2007 - 23:52
What do you mean by "it not true IOS"?
and what are the advanced feature?
paolo bevilacqua Tue, 05/15/2007 - 03:50
  • Hall of Fame,
    Founding Member
Hi, did you read the data sheet for the 500?
It does not have a CLI, web-configuration only.
Whatever is not included in the GUI configuration, may be "advanced" and you do not have it. It's basically a low-cost switch for SMB customer, not a transport/aggregation switch.
nrichie Wed, 05/16/2007 - 12:21
The CE500 uses "smartports" meaning that you specify what the end point is and it sets what it considers to the be best configuration..point and click. There is no console port and no access to anything other than the web interface. I sold one to a client and had many problems with it, we replaced it with a 3650 and I have not quoted any more.
Also, the 500 has PoE but the 2960 does not.
Hope this helps.
sa182802 Wed, 05/16/2007 - 21:21
If using the web interface only without any console is OK for us, what are the other problems that you faced?
