Unity 4.0(5) - Otions after leaving the message
May 14th, 2007
I'm trying to create a subscriber that after leaving the message will not give any options and will disconnect. I managed to remove the Urgent/Regular option but I can't figure out how to remove the prompt to dial extension.
Hillel.
Overall Rating: 5 (1 ratings)
mchandak Mon, 05/14/2007 - 08:06
  • Gold, 750 points or more
Under Subscriber settings, click on Messages and what is the setting for "After message action:". Change it to "Send caller to" and from the Drop down, select "Hang Up". This should remove all prompts and disconnect the call
