PIX 506e and Moneris Debit Terminals
May 14th, 2007
Ok, newbish to cisco stuff, just put in a new 506e. Everything is working so far, except now my high speed debit/credit terminals will not communicate through the router. Moneris says port 443 has to be "open". Well, it is, isn't it? I can check my account balance online, which is a secure https connection, with no problems. Do i need to create 2 specific rules to allow traffic on that port to those terminals?
Thank you for your time.
laurent.geyer Mon, 05/14/2007 - 07:49
What's the direction of the TCP/443 traffic? From the outside to the inside or from the inside to the outside?
maury_macdonald Mon, 05/14/2007 - 08:00
Well, thats a good question. I'm assuming its outside to inside, which should have no issues. We swipe the debit card, and it contacts a server somewhere, then sends back a reply. But, its not communicating properly, so it reverts to the dial backup. I can ping from the terminal, but its communication to its server is not functioning.
laurent.geyer Mon, 05/14/2007 - 08:14
What does your NAT setup look like?
sh nat
sh global
Feel free to sanitize the output if you need to.
maury_macdonald Mon, 05/14/2007 - 08:52
Not much to sanitize really :)
sh nat
nat (inside) 0 access-list inside_outbound_nat0_acl
nat (inside) 1 0 0
sh global
global (outside) 1 interface
maury_macdonald Mon, 05/14/2007 - 09:26
"Well, thats a good question. I'm assuming its outside to inside, which should have no issues."
I beleive i meant "inside to outside", sorry if that caused any confusion.
acomiskey Mon, 05/14/2007 - 10:27
So it's...
Terminals -> Inside PIX -> Outside PIX -> Internet -> Server
Is this traffic from the terminal to server go over vpn or is that nat exemption for something else?
maury_macdonald Mon, 05/14/2007 - 10:45
I have a VPN setup using the Pix and the cisco VPN client. This will be for my remote users to use for remote access so i can lock down the rdp ports currently used.
maury_macdonald Thu, 05/17/2007 - 13:30
Looks like it was an issue with one of my wireless bridges not getting rebooted after the new router install.
Thanks for the effort though!
