Paolo Bevilacqua Mon, 05/14/2007 - 09:40
Hmm no, what sense it would make? Use a loopback address if you have multiple interfaces connecting to the other end of the tunnel.
s-durando Mon, 05/14/2007 - 22:34
I have one router at remote site and two routers at headquarter site with HSRP configured between them. If I want to configure only one tunnel interface at remote site, can I use headquarter's HSRP address as tunnel destination?
Paolo Bevilacqua Tue, 05/15/2007 - 03:18
No, you will need to configure two tunnels, one per router. The end result will be the same.
minumathur Mon, 05/14/2007 - 21:56
i think it is not possible ,because i check command line in router, but nothing i can found out similar to that.
-Minu
