Lock-ups on MCS-7825 after after OS Upgrade to 2000.4.4aSR6
May 14th, 2007
About 3 weeks ago, I upgraded some MCS-7825 & MCS-7835 servers to 2000.4.4aSR6. Since then, one of the 7825's has been rebooting on its own almost twice a day. The other 7825 and 7835s are operating fine.
Anybody else encountering a problem with this? I see in the release notes, some BIOS and firmware updates are included for the 7825, and am suspecting this is the problem.
espereir Thu, 06/07/2007 - 22:48
Do you have any related errors on the App or Sys logs? Do you have a DrWatson crash file that we can check?
Brad Martin Fri, 10/05/2007 - 11:42
I just ran into the same problem with 7835 moving from 4.4aSR4 to 4.5bSR3. Did you ever find a solution?
johnnylingo Fri, 10/05/2007 - 12:01
My problems actually turned out to be hardware, I think. I reviewed the logs and found out it had been happening for several months.
Brad Martin Fri, 10/05/2007 - 12:03
Did you get a blue screen before the reboot? Did the errors show in event logs?
johnnylingo Fri, 10/05/2007 - 12:07
Event logs showed the reboots had been happening ever since the server was installed by a vendor, about 3 times a week.
