ccm 5.1 mgcp reistering problem
I have a strange problem. Trying to register vg224 using mgcp. Register on ccm (type/protocol etc.), add on vg224:
ccm-manager server config 192.168.0.1
ccm-mamager config
After that vg224 download config from ccm, but it can't register:
*Mar : cmapp_mgr_process_ev_active_host_failed: Active host 0 (192.168.0.1) failed
*Mar : cmapp_mgr_check_hostlist: Active host is 0 (192.168.0.1)
*Mar : cmapp_try_fallback(set_to_mode=ON)
*Mar : cmapp_shut_backhaul: backhaul link shutdown is not configured
*Mar : cmapp_try_fallback: fallback is not configured
*Mar : cmapp_host_fsm: Processing event REGISTRATION_NEEDED for host 0 (192.168.0.1) in state REGISTERING
*Mar : cmapp_mgcp_send_rsip: ip_addr=192.168.0.1 port=2427 if_type=-1, slot=0,subunit=0 rst_type=3
Port 2427 is default for mgcp, not changed, port 2428 reachable (mgcp keep alive). Trying to telnet on ccm on port 2427 but get "connection reject". Why??? Host 192.168.0.1 reachable, ccm-agent use IP address, no connectivity problem between them...
gogasca Mon, 05/14/2007 - 11:04
  • Green, 3000 points or more
2428 is for ISDN backhaul.
Do you have other MGCP GW working?
If you do an netstat -an 2427|2428 is in listening state?
Could you please paste your config, do a no mgcp mgcp but before enable debug mgcp packet and send us the output.
thisisshanky Mon, 05/14/2007 - 12:00
  • Purple, 4500 points or more
Can you paste your remaining MGCP config?
VG224 Config
ccm-manager mgcp
ccm-manager music-on-hold
ccm-manager config server 192.168.0.1
ccm-manager config
mgcp
mgcp call-agent 192.168.0.1 2427 service-type mgcp version 0.1
mgcp dtmf-relay voip codec all mode out-of-band
mgcp rtp unreachable timeout 1000 action notify
mgcp modem passthrough voip mode nse
mgcp package-capability rtp-package
no mgcp package-capability res-package
mgcp package-capability sst-package
no mgcp package-capability fxr-package
no mgcp timer receive-rtcp
mgcp sdp simple
mgcp validate call-agent source-ipaddr
mgcp rtp payload-type g726r16 static
mgcp profile default
DEBUG:
*Mar 1 00:05:21.935: cmapp_mgr_process_mgcp_oper_state_change()
*Mar 1 00:05:21.939: cmapp_mgr_check_hostlist: Active host is 0 (192.168.0.1)
*Mar 1 00:05:21.939: cmapp_mgr_check_hostlist: Host 0 (192.168.0.1) going active
*Mar 1 00:05:21.939: cmapp_host_fsm: Processing event GO_ACTIVE for host 0 (192.168.0.1) in state DOWN
*Mar 1 00:05:21.939: cmapp_start_host_tmr: Host 0 (192.168.0.1), tmr 0, duration 15000
*Mar 1 00:05:21.939: cmapp_open_new_link: Open link for [0]:192.168.0.1
*Mar 1 00:05:21.939: cmbh_open_tcp_link: Opening TCP link with Rem IP 192.168.0.1, Local IP 192.168.0.1, port 2428
*Mar 1 00:05:21.939: cmapp_open_new_link: Open initiated OK: Host 0 (192.168.0.1), session_id=62DE7D54
*Mar 1 00:05:21.939: cmapp_host_fsm: New state ACTIVE_OPENING for host 0 (192.168.0.1)
*Mar 1 00:05:21.943: cmbh_tcp_open_ind: TCP open succeeded for 192.168.0.1, calling callback.
*Mar 1 00:05:21.943: cmapp_host_fsm: Processing event CONN_OPEN for host 0 (192.168.1.250) in state ACTIVE_OPENING
*Mar 1 00:05:21.943: cmapp_stop_host_tmr: for host 0 (192.168.0.1)
*Mar 1 00:05:21.943: cmapp_mgr_send_rehome: new addr=192.168.0.1,port=2427
*Mar 1 00:05:21.943: cmapp_host_fsm: New state CHECK_MGCP_REG for host 0 (192.168.0.1)
*Mar 1 00:05:21.943: cmapp_check_def_mgc: MGC conn stat = 3
(1=UNKNOWN,2=CONNECTED,3=CONNECTING,4=NO_DNS_NAME,5=NO_RESPONSE)
*Mar 1 00:05:21.943: cmapp_host_fsm: Processing event MGCP_REGISTERING for host 0 (192.168.0.1) in state CHECK_MGCP_REG
*Mar 1 00:05:21.943: cmapp_mgcp_send_rsip: ip_addr=192.168.0.1 port=2427 if_type=-1, slot=0,subunit=0 rst_type=3
*Mar 1 00:05:21.943: cmapp_start_host_tmr: Host 0 (192.168.0.1), tmr 0, duration 30000
*Mar 1 00:05:21.943: cmapp_host_fsm: New state REGISTERING for host 0 (192.168.0.1)
admin: show network all
I'll check and there is no 2427 port listening...
