confi t
cisco steps
Hi again
I am trying to config one of the 2610 router, I lost password so I did recovery.. got to chng the config reg back to 0x2102 .now I am trying to config term but I get this msg .. did I did anything wrong and who I can solve it?
by the way I did save the runnin config
Router(config)#interface ethernet ?
<0-1> Ethernet interface number
Router(config)#interface ethernet0
% Incomplete command.
3 Accepted Solutions
Jon Marshall
Try one of these 2 things
1) from enable mode "show ip interface brief". This will show you what interfaces the router has.
2)Router(config)# interface ethernet0 ?
Should tell you what router is looking for on the command line
Jon
I believe that both suggestions that Jon gives are good and I particularly like the first one.
I suspect that it is looking for Ethernet0/0 or Ethernet0/1 or something like that.
Rick
Rick
karim
There is not really any difference between ethernet0 and ethernet0/0. A router will have one or the other but not both. Which version of naming you use depends on the particular model of router, some use just the single number and some use the 0/0.
I assume that the training doc that you have was written for one of the routers that used only the single number and now you are using a slightly different model of router.
Rick
Rick
Jon Marshall
Jon
Rick
Rick
well I find out that I need to do ethenet 0/0.. but the training Doc that I have only said do the command :
interface etherent0
I guess that solves the problem or is there difference b/w >>interface etherent0 and >> interface etherent0/0
R1>show ip interface brief
Interface IP-Address OK? Method Status Prot
ocol
Ethernet0/0 unassigned YES NVRAM administratively down down
Serial0/0 unassigned YES NVRAM administratively down down
Serial0/1 unassigned YES NVRAM administratively down down
R1>enable
R1#config t
Enter configuration commands, one per line. End with CNTL/Z.
R1(config)#interface ethernet ?
R1(config)#interface ethernet 0/0
R1(config-if)#
thanks
karim
Rick
Rick
