Catalyst 3750 Setup with SAN
May 14th, 2007
I am trying to setup a Catalyst 3750 to work with a SAN and two servers. The lights on the switch will not light up on the switch, the servers or the SAN. Any ideas on how to get this fixed.
spremkumar Mon, 05/14/2007 - 19:58
did you check the interface status on the switch side ?
also did you see any logs out there in the switch which can provide vital info on the reason why the light is not up..
did you try to reverse the tx/rx pair on one end of the connectivity.
finally did you check out for the speed and the duplex mode on the switch port side ?
cadstillo Tue, 05/15/2007 - 04:41
I will check this out. Thanks
I did reverse the pair on one end, didnt help.
