2 questions about PPTP VPN on 878
I've configured my 878 router as a PPTP VPN server. It works very fine and very quickly. Using the XP VPN client from a remote site, I can "see" all servers in my network.
2 questions
1) When doing telnet on the 878 through the VPN, it is very slow.
2) I would have to get access to the internet through the VPN. But this does not work.
What should I change in this config :
Thanks in advance,
Guy
version 12.3
no service pad
service timestamps debug datetime localtime show-timezone
service timestamps log datetime localtime show-timezone
service password-encryption
service linenumber
service sequence-numbers
hostname ineo-21029
boot-start-marker
boot-end-marker
no logging buffered
enable secret 5 .....
username ...
aaa new-model
aaa authentication login default local
aaa authorization exec default local
aaa session-id common
ip subnet-zero
no ip cef
no ip dhcp use class
ip name-server 212.100.160.51
ip name-server 212.100.160.52
ip port-map ms-sql port 1433
vpdn enable
vpdn-group 1
! Default PPTP VPDN group
accept-dialin
protocol pptp
virtual-template 1
no ftp-server write-enable
isdn switch-type basic-net3
controller DSL 0
mode atm
line-term cpe
line-mode 2-wire line-zero
dsl-mode shdsl symmetric annex B
line-rate auto
interface BRI0
no ip address
shutdown
interface ATM0
description === to PE/Router ====
no ip address
ip accounting output-packets
load-interval 30
no atm ilmi-keepalive
interface ATM0.1 point-to-point
description $ES_WAN$
pvc 8/35
oam-pvc manage 5
oam-pvc manage cc end direction both
oam retry 3 3 1
oam retry cc end 3 3 30
encapsulation aal5mux ppp dialer
dialer pool-member 1
interface FastEthernet0
no ip address
interface FastEthernet1
no ip address
interface FastEthernet2
no ip address
interface FastEthernet3
no ip address
interface Virtual-Template1
ip unnumbered Vlan1
peer default ip address pool test
no keepalive
ppp encrypt mppe auto
ppp authentication pap chap ms-chap ms-chap-v2
interface Vlan1
description $FW_INSIDE$
ip address 192.168.2.2 255.255.255.0
ip nat inside
ip virtual-reassembly
interface Dialer1
description $FW_OUTSIDE$
ip address negotiated
ip nat outside
encapsulation ppp
dialer pool 1
dialer-group 1
no cdp enable
ppp chap hostname ....
ppp chap password ....
ppp pap sent-username ....
ip local pool test 192.168.2.240 192.168.2.250
ip classless
ip route 0.0.0.0 0.0.0.0 Dialer1
ip http server
no ip http secure-server
ip nat inside source list 101 interface Dialer1 overload
access-list 101 permit ip 192.168.2.0 0.0.0.255 any
dialer-list 1 protocol ip permit
control-plane
line con 0
exec-timeout 120 0
no modem enable
transport preferred all
transport output all
stopbits 1
line aux 0
line vty 0 4
access-class 113 in
exec-timeout 0 0
transport input all
scheduler max-task-time 5000
thomas.chen Fri, 05/18/2007 - 10:31
  • Silver, 250 points or more
I think for the slow telnet problem you are running into an MTU issue. Because IPSec adds overhead, sometimes packets are dropped because they are too large. Try to lower the MTU on the devices and then try telnet. Regarding your second question, VPN is used to get a private network running over the internet, so you wont need VPN to access the internet.
Thanks for this message.
Finding no solution to my problem, i've switched to other tools : Easy VPN server in the router + Cisco VPN client. My 2 questions have now received a positive answer.
I was very important for me to get Internet acess through the VPN. Because we rent a dedicated server, located somewhere, and the access to this server is firewall-protected on our public IP address. Thus, when i'm outside and want to manage this serveur, i've to connect via VPN at our central office first.
Best regards,
Guy
