Network Monitoring
May 14th, 2007
Without the use of 3rd party applications, how can I perform monitoring on a router? For example, how can I monitor a specific workstation with it's I.P address or hostname with information on what type of traffic it's traversing inbound and outbound to and from the internet? For eg, I would like to monitor data transmissions, the source of the transmission (ie youtube video downloading, ebay browsing), etc etc
Thank You
mohammedmahmoud Mon, 05/14/2007 - 12:09
You can use ip cache flow under the internet interface "ip route-cache flow", and then use show ip cache flow.
HTH, please do rate all helpful replies,
Mohammed Mahmoud.
danny9797 Tue, 05/15/2007 - 10:37
I attempted the command but it's invalid.
I have three options if I do an ip route-cache ?
Which do you recommend?
mohammedmahmoud Tue, 05/15/2007 - 10:56
You have to use "ip route-cache flow" under the main interface, while the "ip flow ingress" was an enhancement to be used under subinterfaces.
Mohammed Mahmoud.
spremkumar Mon, 05/14/2007 - 19:03
In addition to net flow you can also think off using NBAR (which is memory extensive) to export the details like your traffic with both in/out bytes/packets to an external system so that you can verify the amount of data transmission with respect to each port or application.
danny9797 Tue, 05/15/2007 - 11:16
I want to enable the logging on a cisco 2500 that I have here. This router, routes traffic from the LAN through a T1 to another network. I'm trying to establish the netflow on this router, but it doesn't accept the command. I tried to establish it on any of the interfaces but none of them seem to work. It has different switches in replacement to "flow" as stated in my previous comment.
Any ideas?
glen.grant Tue, 05/15/2007 - 15:58
I doubt an old 2500 supports netflow though I don't know that for sure . You would have to look at some of the last codes produced for 2500 to see if it supported netflow or not .
danny9797 Wed, 05/16/2007 - 06:42
I believe they do
I tried the command on a 2600 router and im having the same issue.
The only difference is that im getting different switches available to me with the ip-route cache command
Can you enable netflow on ethernet and serial interfaces?
The 2600 is running version 11.3 and the 2500 is running 10.3, if this matters.
Any help would be appreciated
