Network Device Group question in ACS
May 14th, 2007
Do the AAA clients in a network device group need to use the same key as the one defined in the actual device group itself, or is it separate? I'm confused between the two as with each client,you give it a key. Just wondering if that needs to match the key for the device group itself??
Jagdeep Gambhir Mon, 05/14/2007 - 15:43
  • Red, 2250 points or more
Hi ,
The NDG key configuration overrides the AAA Client configuration. So if you have both NDG and aaa client key : ACS will take NDG key into considration and will ignore aaa client key.
