Question about PPPoE and DNS
May 14th, 2007
I've got a Cisco1841-AdvansedSecurity (don't ask me what for) and PPPoE connection through Ethernet-DSL modem.
Before 1841 I've used IPcop-Linux Firewall. When PPPoE connection starts, Linux automatically recieved couple of DNS server from ISP, so I don't have to add it manually.
Is there a way to keep same thing in 1841, without "ip name-server bla.bla.bla.bla"?
Right now my config looks that way:
vpdn enable
vpdn-group 1
interface FastEthernet0/1
description WAN connection
no ip address
duplex auto
speed auto
pppoe enable group global
pppoe-client dial-pool-number 1
interface Dialer1
mtu 1492
ip address negotiated
ip virtual-reassembly
encapsulation ppp
ip tcp adjust-mss 1452
dialer pool 1
dialer-group 1
keepalive 120 20
no cdp enable
ppp authentication chap callin
ppp chap hostname LOGIN
ppp chap password PASSWORD
ip route 0.0.0.0 0.0.0.0 Dialer1
Overall Rating: 5 (1 ratings)
mohammedmahmoud Mon, 05/14/2007 - 14:11
  • Green, 3000 points or more
AFAIK, this can't be done on a cisco router, "ip address negotiated" negotiate the IP address only.
Plus the "ip name-server" command doesn't need any frequent changes, its a one time configuration command, it shouldn't be a problem.
HTH, please do rate all helpful replies,
Mohammed Mahmoud.
vpmorozov Tue, 05/15/2007 - 09:58
Hello, Krisztian!
I've added "ppp ipcp dns request accept" and "ppp ipcp predictive", now router resolves address without "ip name-server", so - this method WORKS! :-)
But I found 2 new questions:
1. DDNS tries to update HTTP address BEFORE router gets DNS through PPP IPCP. And I've not found any way to suspense DDNS update for a couple of seconds. Using workaround - added "ip host members.dyndns.org I.P.ADD.RESS"
2. How can I use DNS, obtained throug PPP IPCP, in DNS spoofing (DNS proxy) for my LAN clients, which uses router IP as DNS.
Thanks a lot, your first advice was very useful! :-)
