MDS9509: show tech-support write error
May 14th, 2007
I have a mds9509 and when attempting to redirect the output of the "show tech-support" command to either ftp or a local file on the switch, I receive the error: "Write error: No space left on the device".
Bootflash and system resources all look fine:
MDS9509a# show tech-support > ftp: mds9509a_051407.txt
PXDC-MDS9509a# dir bootflash:
12288 Dec 31 16:01:02 1979 lost+found/
14700544 Jan 17 10:15:23 2007 m9500-sf1ek9-kickstart-mz.3.0.2a.bin
67051932 Jan 17 10:16:23 2007 m9500-sf1ek9-mz.3.0.2a.bin
0 Apr 26 21:25:33 2006 sec_perm
Usage for bootflash://sup-local
95830016 bytes used
88729600 bytes free
184559616 bytes total
MDS9509a# show system resources
Load average: 1 minute: 0.07 5 minutes: 0.05 15 minutes: 0.01
Processes : 134 total, 1 running
CPU states : 0.0% user, 0.0% kernel, 100.0% idle
Memory usage: 1028604K total, 731984K used, 296620K free
5780K buffers, 42003K cache
MDS9509a# show system internal flash
Filesystem 1k-blocks Used Available Use% Mounted on
/dev/root 204800 39620 165180 20% /
proc 0 0 0 - /proc
none 409600 111080 298520 28% /isan
none 153600 10028 143572 7% /var/sysmgr
none 204800 104128 100672 51% /var/sysmgr/ftp
none 102400 7916 94484 8% /dev/shm
none 20480 14008 6472 69% /volatile
none 2048 20 2028 1% /debug
none 20480 2640 17840 13% /var/sysmgr/startup-cfg
devpts 0 0 0 - /dev/pts
/dev/hd-pss 20077 1698 17343 9% /mnt/pss
/dev/hd-bootflash 180234 84279 86650 50% /bootflash
127.1.1.5:/mnt/bootflash/
180234 84279 86650 50% /bootflash_sup-remote
127.1.2.4:/mnt/cf/partner
185683 4937 171159 3% /modflash_4-1
Any ideas? I can run the show tech-support from Fabric Manager to my ftp server without any problems.
Aran
Overall Rating: 5 (2 ratings)
colin.mcnamara Mon, 05/14/2007 - 19:50
  • Bronze, 100 points or more
One thing to keep in mind, is that when you run a command through Fabric Manager, it is executed VIA snmp. When you run a command through the CLI it is executed through the command shell.
I was able to replicate what I believe is your problem in the lab by filling up the volatile partition, then running a command that writes to it (show tech).
Delete the some unused files out of your volatile partition, make sure the space is reclaimed, then run your command. You should be fine.
If you find this helpful, please rate it.
--Colin
aran_hoffmann Tue, 05/15/2007 - 11:10
Thanks, that was exactly the issue. Once I cleared the volatile directory (there was an old show tech-support that I stored locally) that resolved the problem.
dmcloon Mon, 05/14/2007 - 20:18
Hi Aran,
The "Write error: No space left on the device" is due to the /volatile area being insufficient size to store the show tech output. We put it in /volatile before it is ftp'd off the MDS. As of 3.1(3) we increased the /volatile size to 40MB which should prevent the error.
It works from FM because FM does not rely on /volatile. FM does a CLI login behind the scene and screen scrapes the show tech output from the telnet data stream.
Dallas
Sydney TAC
aran_hoffmann Tue, 05/15/2007 - 11:11
Thanks for the extra information on the issue. I appreciate the answer.
Trending Topics: Storage Networking
