Can an Agent selectively login to certain CSQs
Answered Question
May 14th, 2007
Hello all,
We use CRS 4.0(5) and CCM 4.1.3. Agent uses CAD to login to system. My question is:
If an agent is part of multiple CSQs, if there a way for the agent to login to selectively login to certain queues not others? I know you can either pull agent out of the CSQs or set the skill to a level lower than minimum required. But both of them need Administrator to change it. It would be nice if Agent or Supervisor can have the capability to choose which queue agent want to login.
Anyone know if it is possible or not?
Correct Answer by lpezj about 9 years 10 months ago
I think that is not possible, in this moment, to change for a supervisor or agent dinamically their CSQs or skills.
I think that this feature will be available for supervisors in version 5 of IPCC Express.
Take a look to this brochure:
http://www.cisco.com/en/US/products/sw/custcosw/ps1846/products_data_sheet0900aecd805e1d54.html
Hope this helps,
Juan Luis
Overall Rating: 4 (1 ratings)
Correct Answer
lpezj Mon, 05/14/2007 - 23:24
  • Gold, 750 points or more
Hope this helps,
Juan Luis
