PIX SIte-SIte VPN & VPN client connections
May 14th, 2007
I have a PIX which has been in production with remote VPN clients working fine. I just added a second pix to bring up a site - site tunnel. I can't get both to work at the same time. If the Site - Site is up the clients cannot connect and vis versa. Once I add the "crypto map 'dyn-map' interface outside" for the site - site the clients drop. What am I missing?
oabduo983 Mon, 05/14/2007 - 17:56
  • Bronze, 100 points or more
when you have multiple VPN connections terminating on your firewall you apply only 1 static map to the interface...
for the RA VPN you map your dynamic map to your static map. The sequence number in the Dynamic map and static map can be the same or different.
For the site to site tunnel, you will NOT create a dynamic map. You only create a static map with the same name but a DIFFERENT SEQUENCE NUMBER.
Make sure your ACL's are right, and you are bypassing nat (nat (inside) 0 command)...
if still not working, post your configuration and I'll try to support you.
baldcat11 Mon, 05/14/2007 - 19:51
The site - site was up and I was able to connect via VPN client but I couldn't pass traffic. Any additional help will be greatly appreciated.
interface ethernet0 auto
interface ethernet1 100full
nameif ethernet0 outside security0
nameif ethernet1 inside security100
hostname Largo
domain-name ciscopix.com
fixup protocol dns maximum-length 512
fixup protocol ftp 21
fixup protocol h323 h225 1720
fixup protocol h323 ras 1718-1719
fixup protocol http 80
fixup protocol rsh 514
fixup protocol rtsp 554
fixup protocol sip 5060
fixup protocol sip udp 5060
fixup protocol skinny 2000
fixup protocol smtp 25
fixup protocol sqlnet 1521
fixup protocol tftp 69
names
access-list 101 permit ip 192.168.51.0 255.255.255.0 172.20.1.0 255.255.255.0
access-list 101 permit ip 192.168.51.0 255.255.255.0 192.168.62.0 255.255.255.0
access-list usvvpngroup_splitTunnelAcl permit ip 192.168.51.0 255.255.255.0 any
access-list CLIENT permit ip any 172.20.1.0 255.255.255.0
access-list NoNAT permit ip 192.168.51.0 255.255.255.0 192.168.62.0 255.255.255.0
pager lines 24
logging on
logging console debugging
logging host inside 192.168.1.40
mtu outside 1500
mtu inside 1500
ip address outside x.x.x.x 255.255.255.248
ip address inside 192.168.51.1 255.255.255.0
ip audit info action alarm
ip audit attack action alarm
ip local pool usv-pool 172.20.1.1-172.20.1.254
pdm logging informational 100
pdm history enable
arp timeout 14400
global (outside) 1 interface
nat (inside) 1 0.0.0.0 0.0.0.0 0 0
static (inside,outside) x.x.x.x 192.168.51.10 netmask 255.255.255.255 0 0
route outside 0.0.0.0 0.0.0.0 x.x.x.x 1
timeout xlate 0:05:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 rpc 0:10:00 h225 1:00:00
timeout h323 0:05:00 mgcp 0:05:00 sip 0:30:00 sip_media 0:02:00
timeout sip-disconnect 0:02:00 sip-invite 0:03:00
timeout uauth 0:05:00 absolute
aaa-server TACACS+ protocol tacacs+
aaa-server TACACS+ max-failed-attempts 3
aaa-server TACACS+ deadtime 10
aaa-server RADIUS protocol radius
aaa-server RADIUS max-failed-attempts 3
aaa-server RADIUS deadtime 10
aaa-server LOCAL protocol local
http server enable
http 192.168.1.0 255.255.255.0 inside
http 172.20.1.0 255.255.255.0 inside
snmp-server host inside 192.168.51.107 trap
no snmp-server location
snmp-server contact
snmp-server community
snmp-server enable traps
floodguard enable
sysopt connection permit-ipsec
crypto ipsec transform-set USVAC esp-des esp-md5-hmac
crypto ipsec transform-set VPN esp-aes-256 esp-sha-hmac
crypto dynamic-map CLIENT 2 match address CLIENT
crypto dynamic-map CLIENT 2 set transform-set VPN
crypto map MYMAP 1 ipsec-isakmp
crypto map MYMAP 1 match address 101
crypto map MYMAP 1 set peer x.x.x.x
crypto map MYMAP 1 set transform-set USVAC
crypto map MYMAP 10 ipsec-isakmp dynamic CLIENT
crypto map MYMAP interface outside
isakmp enable outside
isakmp key ******** address x.x.x.x netmask 255.255.255.252
isakmp policy 10 authentication pre-share
isakmp policy 10 encryption 3des
isakmp policy 10 hash md5
isakmp policy 10 group 1
isakmp policy 10 lifetime 1000
isakmp policy 20 authentication pre-share
isakmp policy 20 encryption aes-256
isakmp policy 20 hash sha
isakmp policy 20 group 2
isakmp policy 20 lifetime 86400
vpngroup usvvpngroup address-pool usv-pool
vpngroup usvvpngroup dns-server 4.2.2.2
vpngroup usvvpngroup default-domain usvacation.org
vpngroup usvvpngroup split-tunnel usvvpngroup_splitTunnelAcl
vpngroup usvvpngroup split-dns usvacation.com
vpngroup usvvpngroup idle-time 1800
vpngroup usvvpngroup password ********
telnet timeout 5
ssh 0.0.0.0 0.0.0.0 inside
ssh timeout 60
console timeout 0
