Do the Cisco 877Ws support WDS?
May 14th, 2007
Hi, I was just wondering if the 877Ws support WDS? The reason why I ask is because I have an 877W and an 1100 series AP and I was wanting to know if it is possible to get WDS working between the two.
Thank you.
Overall Rating: 5 (1 ratings)
Rob Huffman Tue, 05/15/2007 - 05:20
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 IP Telephony, Unified Communications
Hi Will,
Sorry to say the 877W does not support WDS :(
Hope this helps!
Rob
voiper_99 Tue, 05/15/2007 - 15:05
Ah that's OK, thanks for the information. How/where did you find this out from? I have heard conflicting information that it is and that it isn't so it would be great to have a proper reference to look at.
Rob Huffman Wed, 05/16/2007 - 05:28
  • Hall of Fame,
    Founding Member
Hi Will,
You know in this case there is no actual doc the says "the 877W does/does not support WDS" Call me crazy, but I spent a couple of hours last night trying to find a reference doc - nothing! There were 151 related documents but none of them gave an exact answer. Have a look at this 877W list of supported features and note that there is no mention of WDS.
Sorry I couldn't come up with anything more definite :(
Cisco 800 Series Routers
http://www.cisco.com/en/US/products/hw/routers/ps380/products_data_sheet0900aecd8028a976.html
Hope this helps!
Rob
voiper_99 Wed, 05/16/2007 - 15:50
Not a problem Rob, thanks a lot for your help. I really appreciate it.
