V WIC 1MFT G703 E1 CONTROLLER CARD
Answered Question
May 14th, 2007
HI,
V WIC 1MFT G703 E1 CONTROLLER CARD,It will support 2mbps data in 1841 cisco?
KIndly confirm the config:
Config t
Controller E1 0/0/0
channel-group 0 unframed
Config t
int serial 0/0/0:0
bandwidth 2048
ip address x.x.x.x x.x.x.x
Kindly revert back
Correct Answer by Paolo Bevilacqua about 9 years 8 months ago
Another note, if you use "timeslots 1-31", you don't need the G.703 version of VWIC, but just the normal one, that is much less expensive.
The G.703 version is only needed when you absolutely need to support "unframed".
Overall Rating: 5 (2 ratings)
jaffer_sathik2010 Mon, 05/14/2007 - 20:53
Since channel-group is set to 'unframed',It will definitely support 2 mbps speed.
Please rate ,if it is useful.
--Jaffer
minumathur Mon, 05/14/2007 - 22:14
I think you need to use timeslot 1-31 ,please see below command .
channel-group 0 timeslots 1-31
I hope this will help you out.
-Minu
Paolo Bevilacqua Tue, 05/15/2007 - 03:21
There is a difference,
Channel-group 1 timeslots 1-31 is framed at 1.984 Mbps.
Channel-group 1 unframed, is 2.048 Mbps.
On an unframed circuit you can use both.
Of course all the vwic cards supports data.
Correct Answer
Paolo Bevilacqua Tue, 05/15/2007 - 04:04
