Cisco Transport Manager 7.2 for 15454SDH
May 14th, 2007
dear all,
I'm new to optical, the scenario is i have an application Cisco Transport Manager to manage and monitor cisco ONS15454, somehow i have tried to monitor network performance based on total packet input/output, %utilization, my question are:
1. in the Y axis, it show some hexadecimal info that i don't understand, can i change the Y axis info into exact bandwidth (or percentage of bandwidth)
2. can i monitor utilization and availability for ONS device
note: for ring connection i use MXP card consist of 4 GE optical each 1Gbps and 2FC each 2Gbps
please help
Overall Rating: 4 (2 ratings)
jreekers Tue, 05/15/2007 - 10:49
I think I can answer part of this question for you.
The values in the "Y" axis are snmp object retrieved values, which I don't believe you can modify. But you can translate these values to get more information using this tool:
As an example, you can enter "IfinOctets", and it returns information about that MIB object, including the description as follows:
"The total number of octets received on the interface, including framing characters.
Discontinuities in the value of this counter can occur at re-initialization of the management system, and at other times as indicated by the value of ifCounterDiscontinuityTime."
You can do the same for the other values you see on the Y-axis of the charts.
Hope that helps with Question 1.
ranokarno82 Mon, 05/21/2007 - 18:43
Hi Joe,
thx for your info,
but i think the link you've given to me isn't for translate the value of y axis on the graph.
ranokarno82 Thu, 05/24/2007 - 01:36
dear all,
is there any dokumen related to operate "Cisco Transport Manager v7.2".
could anyone explain me about graph:
ifInOctet -> 4.151581E11 for a circuit, but the circuit itself is one of MXP-10DME port bandwidth 1Gbps
thanks before
