CA certificate issue in ACS 4.0 for Windows
May 14th, 2007
How to generate lost private key .pvk file on ACS which is also configured as CA Server, As I would like to register all the available ACS's Servers to CA Server using the same certificate from CA Server. Need a step wise procedure on obtaining certificate from ACS CA server.
your kind response will be of great help.
Thanks in advance
Best Regards,
Windows Server 2003 with SP1, Enterprise Edition, is used so that auto-enrollment of user and workstation certificates for EAP-TLS authentication can be configured. This is described in the EAP-TLS Authentication section of this document. Certificate auto-enrollment and auto-renewal make it easier to deploy certificates and improve security by automatically expiring and renewing certificates.
