Problem configuring CCME features
May 15th, 2007
I have just installed CCME4.0, and i have installed 7961 ip phones. I am trying to configure directory services, MOH for internal calls, and custom ringtones. But it doesnt reflect on the phones. I have enabled all the required files in TFTP and followed all config steps but no go. Can someone please help?
Overall Rating: 4 (1 ratings)
rseiler Tue, 05/15/2007 - 12:07
Directory services are configured by default (you don't need to do anything other than global speeddial.xml file if necessary).
MOH for internal calls requires multicast MOH which has specific router and switch requirements in addition to the CME config. This is clearly documented in the CME 4.0 configuration guide.
Custom ringtones requires you to create a Ringlist.xml file in the routers flash and copy the relevant ringtone (.raw) files into flash as well.
Let me know if you have any additional questions.
moblix123 Wed, 05/16/2007 - 03:11
Thanks a million for your response. i have followed all the config steps but no luck, pls find below my running config and tell me what i'm doing wrong.
Building configuration...
Current configuration : 4648 bytes
! Last configuration change at 10:59:45 UTC Wed May 16 2007
version 12.4
hostname yourname
boot-start-marker
boot-end-marker
! card type command needed for slot/vwic-slot 0/0
no aaa new-model
resource policy
ip subnet-zero
ip cef
no ip dhcp use vrf connected
ip dhcp excluded-address 149.17.18.2
ip dhcp pool cme-pool
network 149.17.18.0 255.255.255.0
default-router 149.17.18.1
option 150 ip 149.17.18.1
no ip domain lookup
ip domain name yourdomain.com
ip multicast-routing
voice-card 0
no dspfarm
interface FastEthernet0/0
ip address 149.17.18.1 255.255.255.0
duplex auto
speed auto
interface FastEthernet0/1
no ip address
shutdown
duplex auto
speed auto
ip classless
ip http server
no ip http secure-server
ip http path flash:
access-list 23 permit 10.10.10.0 0.0.0.7
access-list 23 permit 149.17.0.0 0.0.255.255
access-list 23 permit 149.17.18.0 0.0.0.255
tftp-server flash:cnu41.2-7-6-26.sbn
tftp-server flash:CVM41.2-0-2-26.sbn
tftp-server flash:Jar41.2-9-2-26.sbn
tftp-server flash:TERM41.7-0-3-0S.loads
tftp-server flash:term41.default.loads
tftp-server flash:term61.default.loads
tftp-server flash:RingList.xml
tftp-server flash:Analog1.raw
tftp-server flash:Bass.raw
tftp-server flash:Chime.raw
tftp-server flash:Jamaica.raw
tftp-server flash:Pop.raw
control-plane
telephony-service
load 7961 term61.default.loads
max-ephones 24
max-dn 48
ip source-address 149.17.18.1 port 2000
system message Pinky Inc
create cnf-files version-stamp 7960 May 16 2007 10:49:28
max-conferences 8 gain -6
moh music-on-hold.au
multicast moh 239.0.0.19 port 2000
web admin system name cisco password cisco
dn-webedit
time-webedit
directory entry 1 1001 name test 1
directory entry 2 1003 name test 2
directory entry 3 1002 name test 3
xmltest
ephone-dn 1 dual-line
number 1001
description Test 1
name Test 1
ephone-dn 2
number 1003
description Test 2
name Test 2
ephone-dn 3 dual-line
number 1002
description Test 3
name Test 3
hold-alert 30 originator
ephone-dn 4 dual-line
number 1004
description fdfss
name fsff
ephone-dn 5 dual-line
number 1006
description test 6
no huntstop
ephone-dn 20
number 1000
name paging
paging ip 239.0.0.18 port 2000
ephone 1
mac-address 001B.535C.6E51
button 1:1
ephone 2
mac-address 001B.5413.FC6A
paging-dn 20
button 1:2
ephone 3
mac-address 001B.5413.CBF0
button 1:3
line con 0
line aux 0
line vty 0 4
access-class 23 in
privilege level 15
no login
transport input telnet ssh
line vty 5 15
access-class 23 in
privilege level 15
login local
end
rseiler Wed, 05/16/2007 - 09:32
This is a typical problem that people do all the time. I guess you configured the phones manually, rather than via the GUI?
You left an important *REQUIRED* config item off each of your ephone entries, the phone 'type'. If you don't define a phone type, the phone never gets the default xml file which defines a *BUNCH* of settings for the phone including locale, timezone (on the odd numbered phones), URLs, presence, etc.
Your phones are basically not getting any config from the router. You can 'no create cnf-files' and 'create cnf-files' all you want which will create the default xml files on the router, they are just never getting to the phone because you haven't told the router what phone type they are.
You also would notice that time is wrong, right? In addition, settings/status/status messages on the phone would show that it can't find the SEP.cnf.xml file.
Another troubleshooting trick for this is if you enter the exec command 'show telephony-service tftp-bindings' you will see that all the router is doing is creating the SEP.cnf.xml files as aliases to the XMLDefault.cnf.xml and you don't have those entries yet because you haven't defined the phone type.
To fix this, just do the following, for example:
conf t
ephone 1
type 7961
reset
end
Let me know if this does the trick...
moblix123 Thu, 05/17/2007 - 07:17
Thanks alot, you been the best help. It worked but quite partially. The directory service is working now but the custom ring tones and internal MOH are still not working.
I cant help but notice that each time i creat cnf-files, the file created is version-stamp 7960. Instead of 7961.
I really dont know if that is an issue.
Any other suggestions please?
Paolo Bevilacqua Thu, 05/17/2007 - 07:32
You can ignore the version-stamp file it only applies to older phone types.
For ring files you need to configure correctly "tftp-server" with all the files in list, plust the list itself. Please do "debug tftp events" to see what the phones are requesting".
The MOH, keep in mind for internal calls usually MOH is not used, calling from outside you should be able to hear it.
rseiler Thu, 05/17/2007 - 07:35
Again, the internal MOH requires a specific minimum version of CME and *MUST* use IP multicast. This may require more configuration on the CME router and whatever switch you are using. Do not use a multicast IP that starts with 239.0 (per the documentation).
The ringtones requires a Ringlist.xml file in the routers flash (and permitted by a tftp-server global command) as well as the same for each .raw file you copy to flash as well. I usually copy the .raw files I want from a CallManager server and modify the Ringlist.xml file as necessary.
There are a few good documents on the Cisco site that detail the xml files. It is listed under custom xml applications, I believe. These forums have a bunch of posts reqarding the Ringlist.xml, speeddial.xml, and the newer phone background images...
moblix123 Thu, 05/17/2007 - 23:37
I have followed all the steps for configuring custom ringtones from the manuals but still nothing.
I really appreciate the assistance i have recieved at this forum.
Here is the result for the debug tftp-events
May 18 07:12:30.011: TFTP: Looking for CTLSEP001B5413FC6A.tlv
May 18 07:12:30.187: TFTP: Looking for SEP001B5413FC6A.cnf.xml
May 18 07:12:30.187: TFTP: Opened system:/its/XMLDefault7961.cnf.xml, fd 0, size 917 for process 163
May 18 07:12:30.191: TFTP: Finished system:/its/XMLDefault7961.cnf.xml, time 00:00:00 for process 163
May 18 07:12:30.331: TFTP: Looking for term61.default.loads.loads
May 18 07:12:31.335: TFTP: Looking for English_United_States/mk-sccp.jar
May 18 07:12:31.591: TFTP: Looking for /g3-tones.xml
May 18 07:12:31.991: %IPPHONE-6-REG_ALARM: 25: Name=SEP001B5413FC6A Load= TERM61.DEFAULT Last=Initialized
May 18 07:12:32.243: %IPPHONE-6-UNREGISTER_ABNORMAL: ephone-2:SEP001B5413FC6A IP:149.17.18.5 Socket:2 DeviceType:Phone has unregistered abnormally.
May 18 07:12:32.243: %IPPHONE-6-REGISTER: ephone-2:SEP001B5413FC6A IP:149.17.18.5 Socket:4 DeviceType:Phone has registered.
rseiler Thu, 05/17/2007 - 23:56
This is really very easy so you must be missing something simple.
One thing to look out for is the formatting of the Ringlist.xml file. Be sure there are no extra characters and that the xml syntax is correct.
Note that the file that needs to be in the root of your flash system is 'Ringlist.xml' (note the capital R). Obviously, this would need to be in a tftp-server global statement in the router as well.
Depending on the router platform, be careful with specifying the directory when copying the file: '/Ringlist.xml' may not be the same as 'Ringlist.xml'.
Finally, what is the phone displaying when you try to change the ringer for one of the lines? Is there an error message? File not found?
I'm not sure why your tftp server debug above is looking for /g3-tones.xml. Did you specify that anywhere?
Are you using a locale other than US?
What phoneload are you running on the 7961 phone(s)?
moblix123 Fri, 05/18/2007 - 00:49
Yes i agree, its supposed to be easy but its turned out to be hard nut for me.
i didnt specify for it to look for /g3-tones.xml
The router is a 2811 runing 12.4(3g).
I did copy the file properly into flash and enabled it with tftp command.I took note of the case.
When i go to settings/user pref/rings/... i only see chirp1. i dont get the option to even change to another ringtone.
The phone load i am currently using is TERM41.7-0-3-0S.loads.
I am not using any locale other than US.
Find attached a copy of the Ringlist.xml, you can reconcile it with the running config.
rseiler Fri, 05/18/2007 - 01:07
If you are not seeing the request for the RingList.xml file under the tftp server debug (when you try to change the ringtone for a line), then you have a problem with the CME config or the phone.
Be sure each ephone has a type defined and try the following commands:
conf t
telephony-service
no create cnf-files
create cnf-files
reset all
end
If that doesn't work, I would try the 8.2.2SR1 DST phone load, the 7.0(3) phoneload is quite old.
Are you sure the phone is running the phoneload that you have defined in the router? Try settings/status/firmware on the phone to confirm.
Paolo Bevilacqua Fri, 05/18/2007 - 01:37
keep in mind the newer java-based phones request ringlist.xml only at boot time, and not when changing settings!
moblix123 Mon, 05/21/2007 - 01:35
Eureka! Its working now. i had to replace all the phone files in flash with another one that I got from the Cisco site. And now i have my custom ringtones working.
Thanks all so much for the assistance. you guys are the best.
adandrade Fri, 08/10/2007 - 12:31
Could you explain what you did ? I am having the same issue . thanks
