The PIX Failover is fail
May 15th, 2007
The PIXs are is FW2139 and FW2140. I am user "show failover" command, the PIX is below information.
FW2139
Failover On
Cable status: Normal
Failover unit Primary
Failover LAN Interface: N/A - Serial-based failover enabled
Unit Poll frequency 15 seconds, holdtime 45 seconds
Interface Poll frequency 5 seconds, holdtime 25 seconds
Interface Policy 1
Monitored Interfaces 2 of 250 maximum
Version: Ours 7.2(2)14, Mate 7.2(2)14
Last Failover at: 02:54:59 CST Apr 10 2007
This host: Primary - Active
Active time: 3638325 (sec)
Interface outside (202.144.208.222): Normal
Interface inside (172.25.2.9): Normal
Interface DCN (10.252.135.9): Normal (Not-Monitored)
Other host: Secondary - Standby Ready
Active time: 210 (sec)
Interface outside (202.144.208.212): Normal
Interface inside (172.25.2.14): Normal
Interface DCN (10.252.135.10): Normal (Not-Monitored)
Stateful Failover Logical Update Statistics
Link : state GigabitEthernet3 (Failed)
FW2140
Failover On
Failover unit Secondary
Interface Policy 1
This host: Secondary - Standby Ready
Other host: Primary - Active
Active time: 3638355 (sec)
Link : state GigabitEthernet3 (up)
The FW2139 failover link is fail, but the FW2140 failover link is up.The PIXs are running PIX 7.2(2)14.Is the OS bug?
Please help me.
Thanks and Regards
Stephen
b.hsu Mon, 05/21/2007 - 06:09
  • Silver, 250 points or more
There are 2 failover functions that monitor the interface. The first just monitors the link status and the second monitors the connectivity including the link. The second is triggered when missing hello packets are seen on the interface. If the failover is due to the first function, then it will not show the device as failed. The only time you will see the "failed" state is if the interface itself fails and the missing hello packets start the traffic tests that fail. This should probably be changed.
