RME 4.0.5 database account
Answered Question
May 15th, 2007
I'm trying to install the patch CSCsh39475-1.0. For that I need the configured RME dbaccount. Is there a possibility to find out the current username/password or to overwrite the account?
Hendrik
Correct Answer by Martin Ermel about 10 years 2 weeks ago
for the RME db account the user is fixed to 'DBA' and the password is the one that you have entered during installation of the RME software. If you have not entered a PW then the default 'c2kY2k' should be used.
If you have changed the PW and you cannot remember the PW, then you can reset it with the following cli tool:
You need to stop the processes first:
net stop crmdmgtd (windows)
/etc/init.d/dmgtd stop (solaris)
change the directory to
C:\Program Files\CSCOpx\bin (windows)
/opt/CSCOpx/bin (solaris)
and issue the following cmd
dbpasswd.pl dsn=rmeng encryption=yes npwd=
restart the daemons:
net start crmdmgtd (windows)
/etc/init.d/dmgtd start (solaris)
Overall Rating: 5 (3 ratings)
Correct Answer
Martin Ermel Tue, 05/15/2007 - 06:05
  • Blue, 1500 points or more
