Telnet FROM Cisco Switch 1900
Answered Question
May 15th, 2007
In CCNA ExamCram, I read that we can telnet to s Cisco 1900 switch but we canNOT telnet from one. I just want to know if this is correct or not.
And if the answer is yes, is it correct only for 1900 switch?
I appreciate your help.
Mehdi
Correct Answer by dgoodridge about 9 years 8 months ago
To answer your question, you CANNOT telnet from a 1900 series switch.
Hope that helps.
Doug
Overall Rating: 5 (1 ratings)
Wilson Samuel Tue, 05/15/2007 - 06:02
I really doubt which version of CCNA you are studying as the Cat 1900 has already gone into the EoL long back and last time I have seen them was in a garbage bing!
If 2900? yes, they support telnet from and to both.
persepolis77 Tue, 05/15/2007 - 06:13
Samuel,
I studied Todd Lammle book Study Guide, 5th edition. It should be the last edition per Sybex website!!!
Correct Answer
dgoodridge Fri, 05/18/2007 - 03:12
Hope that helps.
Doug
persepolis77 Fri, 05/18/2007 - 03:15
Hello Doug,
Thanks for your reply.
Yes, I actually found the answer.
and yesterday passed the exam :-)
Thanks again for your consideration.
Mehdi
