Failed Login Notification via SMTP
May 15th, 2007
I am looking for a way to generate an SMTP message in response to a failed login attempt (admin interface access or failed user login attempt). Any suggestion on how I might make this happen is appreciated.
Thanks.
jreekers Tue, 05/15/2007 - 08:23
  • Cisco Employee,
Hi.
I'm not sure what device type you're talking about, but if it's SNMP capable, most IOS devices support traps on failed logins, or if that's not supported, and syslogging is, the device (again, if running IOS) can send a syslog trap for the failed login attempt to a NMS server that supports email notification of events (such as Ciscoworks (LMS)-Device Fault Manager).
Is this the kind of thing you're looking for?
HTH,
-Joe
