T1 CAS IVR FXS Transfer
May 15th, 2007
Can my IVR do a transfer over my T1 CAS FXS loop-start circuit connecting it to my 3845 gateway? This is a CallManager 4.2 H323 gateway. When the IVR does a hook flash, my call is dropped.
Thanks!
Paolo Bevilacqua Tue, 05/15/2007 - 05:52
  • Hall of Fame,
    Founding Member
to support transfer on FXS port you need a TCL script to invoke H.450 call transfer supplementary service, I understand that is not the easiest thing to to setup, other may add something about the integration with IVR and CCM.
