PIX Stateful VPN Failover
May 15th, 2007
Hi!
I just installed a PIX Failover.
Failover is working except w/ VPN. VPN client can connect to the active PIX device whether Primary or Secondary is the active one. Problem is when a Failover occurs and a VPN client is connected, the traffic is not passed through. I had to reconnect the VPN Client.
I was under the impression that VPN Stateful failover will enable the VPN client to continue working even when a Failover occurs.
I'm running PIX v 7.2(2) on both PIX.
PIX UR license on Primary
PIX FO license on Secondary
FO link & Stateful failover link shares the same port - eth 0.
question - is there an additional command to enable VPN stateful failover.
i followed this link as a guide to configure the FO
http://www.cisco.com/en/US/products/hw/vpndevc/ps2030/products_configuration_example09186a00807dac5f.shtml
Thanks!
Anonymous (not verified) Fri, 12/07/2007 - 09:03
