connecting to PIX 515e to configure
Answered Question
May 15th, 2007
I have a PIX 515e that I'm having problems connecting to. We recently changed our network IPs. I believe there are a couple of configuration changes that I need to make to connect via the ASDM or to telnet. So I'd like to connect via the console to make the changes. However, there are tons of "log" info scrolling by which is preventing me from doing anything. Can I stop the logging?
Correct Answer by vitripat about 10 years 1 month ago
I agree with Jon. However, sometimes traffic could be so high that you wont be able to input those commands from the console. PIX would not be able to process them. If this happens, you may have to unplug the network cables so that logs are reduced to almost zero and then try commands Jon suggested from the confg mode at console screen-
no logging console
Vibhor.
Correct Answer by Jon Marshall about 10 years 1 month ago
From enable mode you need to enter
** Edit - sorry, that should be from config mode **
"no logging console"
Just in case someone has left debugging on
"no debug all"
Jon
Overall Rating: 4 (2 ratings)
Correct Answer
Jon Marshall Tue, 05/15/2007 - 06:45
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
"no debug all"
Jon
Correct Answer
vitripat Wed, 05/16/2007 - 06:19
  • Gold, 750 points or more
no logging console
Vibhor.
