Problem with RME 4.0.5 Patch CSCsh39475-1.0
May 15th, 2007
Before the patch installation it's recommended to execute the "DelMismatchVLANConfigVersionsWithBackup.pl" script.
With this script and all other scripts that are coming with the patch I get an error message for line 76:
e:\cscopx\bin\per
l ListMismatchVLANConfigVersionsWithoutBackup.pl
---Begin---
---Please refer the debug.log for the progress...---
Getting Config_Device_Archive.Location,Version_Number from DB:
E:/CSCOpx_data/Archive/\devfiles/1383/VLAN/RUNNING/0
E:/CSCOpx_data/Archive/\devfiles/1383/VLAN/RUNNING/1
E:/CSCOpx_data/Configs/\devfiles/2979/VLAN/RUNNING/0
E:/CSCOpx_data/Configs/\devfiles/2979/VLAN/RUNNING/1
Getting the Config_Device_Archive.Location,Version_Number details from DB ->Comp
leted
DCMA config devfiles Location in the server: = E:\CSCOpx_data\Archive\\devfiles
Retrieving the available Config files from the devFiles location:
Cannot open directory at DelMismatchPrimaryConfigVersionsWithBackup.pl line 76.
The output of the debug-file is not helpful:
---Begin---
Getting the Config_Device_Archive.Location,Version_Number details from DB - Completed
I can not see the reason for the error message. I did everything as described in the readme.
Hendrik
yjdabear Tue, 05/15/2007 - 07:26
That's weird. I'm given the following zip file and install directions by TAC. Now I'm thinking it's not the right patch for CSCsh39475:
Installing From a Local Directory on CiscoWorks Server
You can install the Cisco Lib Dcma Package from a local directory by either:
Using CiscoWorks GUI
Or
Using PSU CLI
To install the Cisco Libdcma Package using CiscoWorks Graphical User
Interface (GUI):
Step 1 Go to Common Services > Software Center > Device Update from the
CiscoWorks homepage.
Step 2 Check the Resource Manager Essentials check box and click Check for Updat
es.
Step 3 Go to the Source Location page and select Enter Server Path.
Step 4 Enter the path where the device package file is stored in the local direc
tory and
click Next.
Step 5 Select Libdcma from the list of Available Device Packages and click
Next.
Step 6 Select Install Device Packages and click Next.
The Installation summary appears with details of the selected device packages.
Step 7 Click Finish.
A window with warnings and installation details appears informing you that all
the daemons will be restarted.
Step 8 Click OK to start the installation.
Any one of the following messages appears during installation:
Page Cannot be Displayed
Page Not Found
Cannot Find Server or DNS
Document contains no data
This behavior is normal for Software Center when the daemon manager restarts.
This may take a few minutes.
Step 9 Close the browser window and log into CiscoWorks again.
You can check the installation status from the Cisco.com, by selecting
Common Services > Software Center > Activity Log > Event Log.
To ensure that the installation is successful, go to Common Services > Software
Center > Device Update. Click Resource Manager Essentials and ensure that
the device package you installed is listed.
Using PSU CLI
To install the Cisco Libdcma Package Support Updater Command Line
Interface (PSU CLI):
Step 1 Download the package to a local directory on CiscoWorks server.
Step 2 Enter the following commands to install the package.
On Solaris:
NMSROOT/bin/PSUCli.sh -p rme -install -src local directory Libdcma
On Windows:
NMSROOT\bin\PSUCli -p rme -install -src local directory Libdcma
Replace NMSROOT with the actual path of the CiscoWorks installation directory.
The following are the default locations of NMSROOT on Solaris and Windows:
On Solaris: /opt/CSCOpx/
On Windows: C:\Progra~1\CSCOpx
Verifying Installation
To check whether the Cisco Libdcma Package is installed successfully:
Step 1 Log into CiscoWorks.
Step 2 Go to Common Services > Software Center > Software Update.
The Software Updates page appears.
Step 3 Click Resource Manager Essentials in the Device Updates page.
The Package Map for Resource Manager Essentials appears.
Step 4 Locate Libcma in the Package Map, and check its version.
If the version is 1.8.1, the installation is successful.
Archive: CSCsh39475.zip
inflating: com/cisco/nm/xms/psu/pkgs/LibDcma/PkgDescr.class
(snipped...)
inflating: com/cisco/nm/xms/xdi/pkgs/LibDcma/LibDcma_Msg.properties
Joe Clarke Tue, 05/15/2007 - 07:41
There are two parts to the patch. The first is a Perl script that cleans up the bad file system components for the failing devices. The other is the actual code to make sure this does not happen again. If you do not run the Perl script, then you must delete the bad devices from RME, then re-add them to completely fix the problem.
yjdabear Tue, 05/15/2007 - 07:51
Do I need the script(s)? I'm not getting any symptoms of the bug, just want to patch it as a preventive measure. How do I install this patch? Keep it zipped, and follow the directions regarding LibDcma?
inflating: com/cisco/nm/xms/xdi/pkgs/LibDcma/Descriptor.class
inflating: com/cisco/nm/xms/xdi/pkgs/LibDcma/analyzer/RawDataGeneratorIf.class
inflating: com/cisco/nm/xms/xdi/pkgs/LibDcma/analyzer/GroupingCriteria.class
inflating: com/cisco/nm/xms/xdi/pkgs/LibDcma/analyzer/CommandGrouperFactoryIf.class
inflating: com/cisco/nm/xms/xdi/pkgs/LibDcma/analyzer/ConfigletRule.class
inflating: com/cisco/nm/xms/xdi/pkgs/LibDcma/analyzer/ConfigletRange.class
inflating: com/cisco/nm/xms/xdi/pkgs/LibDcma/analyzer/CommandGrouper.class
inflating: com/cisco/nm/xms/xdi/pkgs/LibDcma/analyzer/MatchFinderIf.class
inflating: com/cisco/nm/xms/xdi/pkgs/LibDcma/analyzer/ConfigFileReader.class
inflating: com/cisco/nm/xms/xdi/pkgs/LibDcma/analyzer/ConfigReader.class
inflating: com/cisco/nm/xms/xdi/pkgs/LibDcma/analyzer/ConfigDiffer.class
inflating: com/cisco/nm/xms/xdi/pkgs/LibDcma/analyzer/ConfigMetaData.class
inflating: com/cisco/nm/xms/xdi/pkgs/LibDcma/analyzer/ProcessedDataGeneratorIf.class
inflating: com/cisco/nm/xms/xdi/pkgs/LibDcma/analyzer/ConfigArrayReader.class
inflating: com/cisco/nm/xms/xdi/pkgs/LibDcma/analyzer/SuccessorConfiglet.class
inflating: com/cisco/nm/xms/xdi/pkgs/LibDcma/analyzer/SimpleMatchFinder.class
inflating: com/cisco/nm/xms/xdi/pkgs/LibDcma/analyzer/DeviceConfigletRules.class
inflating: com/cisco/nm/xms/xdi/pkgs/LibDcma/analyzer/PatternMatchConfiglet.class
inflating: com/cisco/nm/xms/xdi/pkgs/LibDcma/analyzer/DummyConfiglet.class
inflating: com/cisco/nm/xms/xdi/pkgs/LibDcma/analyzer/DelimiterConfiglet.class
inflating: com/cisco/nm/xms/xdi/pkgs/LibDcma/analyzer/IndentationConfiglet.class
inflating: com/cisco/nm/xms/xdi/pkgs/LibDcma/analyzer/SimpleCommandGrouperFactory.class
inflating: com/cisco/nm/xms/xdi/pkgs/LibDcma/analyzer/DefaultConfiglet.class
inflating: com/cisco/nm/xms/xdi/pkgs/LibDcma/cmdHandler/InteractiveCmdHandlerIf.class
inflating: com/cisco/nm/xms/xdi/pkgs/LibDcma/cmdHandler/PromptAndResponse.class
inflating: com/cisco/nm/xms/xdi/pkgs/LibDcma/cmdHandler/ResponseHandlerImpl.class
inflating: com/cisco/nm/xms/xdi/pkgs/LibDcma/cmdHandler/PromptsAndResponseHandlerImpl.class
inflating: com/cisco/nm/xms/xdi/pkgs/LibDcma/persistor/ConfigOperatorFactoryIf.class
inflating: com/cisco/nm/xms/xdi/pkgs/LibDcma/persistor/OperatorCacheManager.class
Joe Clarke Tue, 05/15/2007 - 07:46
I do not see this script in the official patch. You should go back to the TAC engineer that provided this to you, and work with them to understand these errors.
Joe Clarke Tue, 05/15/2007 - 09:31
Nevermind, I see the official patch has been published to Cisco.com. It has this script. This error means the script cannot access the directory E:\CSCOpx_data\Archive\\devfiles. Does it exist?
hleschin Mon, 05/21/2007 - 01:15
No, the directory E:\CSCOpx_data\Archive\\devfiles doesn't exist.
We us instead of it the directory E:\CSCOpx_data\Configs\ to archive the config-files. This directory is configured in RME\Admin\Config Mgmt\Archive Mgmt\Archive Settings. Could it be that the script doesn't use this value from RME so I have to change it in the scripts ?
Joe Clarke Tue, 05/22/2007 - 08:43
The good news is the archive location is properly specified in regdaemon.xml. The bad news is it appears to be wrong in the database for at least one device (and possibly all). This means the patch will not work for you until the database is cleaned up.
The simplest solution is to completely reinitialize the rmeng database, or restore from a known good backup (i.e. before the archive location was changed). However, if you open a TAC service request, it may be possible to analyze the extent of archive damage to see if there is a more tactical solution. You should be prepared that a reinit may be necessary, though.
