cisco aironet 1100 web interface?
May 15th, 2007
Hello everyone, we use a Cisco Aironet wireless access point here for wireless internet access, I wanted to know what the default web interface address usually is and what the user/pass would be, thanks
Rob Huffman Tue, 05/15/2007 - 08:12
  • Super Red, 40000 points or more
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 IP Telephony, Unified Communications
Hi Sharad,
Here is the required info;
Default IP Address Behavior
Recent Cisco IOS releases have changed the way an unconfigured access point behaves when booted for the first time. This section describes this behavior and provides instructions on how to open the access point's configuration pages.
Cisco IOS Release 12.2(15)JA and Earlier
Login/Password
Cisco/Cisco
Case-sensitive.
SSID
tsunami
Radio status
Enabled
IP Address
Assigned by DHCP
If DHCP disabled, the default IP address is 10.0.0.1.
Cisco IOS Release 12.3(2)JA
Login/Password
Cisco/Cisco
Case-sensitive.
SSID
tsunami
Case-sensitive.
Radio status
Enabled
IP Address
Assigned by DHCP
Cisco IOS Release 12.3(4)JA and Later
Login/Password
Cisco/Cisco
Case-sensitive.
SSID
None assigned
You must create an SSID. See the "Configuring Security Settings" section for additional information.
Radio status
disabled
You must enable the radio interfaces. See the "Enabling the Radio Interfaces" section for additional information.
IP Address
Assigned by DHCP
If DHCP disabled, the access makes several attempts to get an IP address from a DHCP server. If it does not receive an address, it assigns itself an IP address of 10.0.0.1 for 5 minutes and becomes a mini-DHCP server. During this 5 minute window, you can browse to the default IP address and configure a static address. If after 5 minutes the access point is not reconfigured, it discards the IP address and sends DHCP request indefinitely.
Note: If you miss the five-minute window for browsing to the access point at 10.0.0.1, you can power-cycle the access point to repeat the process.
From this good doc;
http://www.cisco.com/en/US/products/hw/wireless/ps4570/products_quick_start09186a008027dfe5.html#wp27797
Hope this helps!
Rob
jaichauh Wed, 05/16/2007 - 05:01
Hi there!
Default IP address is 10.0.0.1 for five minutes. During that five minutes, you can browse to that IP address to configure the unit. If after five minutes the unit has not been reconfigured, it discards the 10.0.0.1 address and reverts to requesting an address from the DHCP server. If it does not receive an address, it sends requests indefinitely. If you miss the five-minute window for browsing to the access point at 10.0.0.1, you can power-cycle the access point to repeat the process.
Default usrename/passowrd = Cisco/Cisco (Capital C)
For reference:
http://www.cisco.com/en/US/products/hw/wireless/ps430/products_configuration_guide_chapter09186a0080606cbe.html
-Jai
Trending Topics: Other Wireless Mobility
client could not be authenticated
Network Analysis Module (NAM) Products
Cisco 6500 nam
reason 440 driver failure
Cisco password cracker
Cisco Wireless mode
