1800 and 2800 routers
May 15th, 2007
Hi ,
2 questions :
1.Is HSRP supported on an 1800 series router , if so which one???
Has anyone practically tested it???Does it work fine????
2. On a 2800 which card should I go for if I need a Channelised E1 connection???
Can I have it on a 2811 ??? If so can I have the Part code please.
Thanks in advance,
Overall Rating: 3.7 (3 ratings)
Craig Norborg Tue, 05/15/2007 - 07:52
1) HSRP is supported on 1800 series routers just fine, we use it all the time. I think its standard in all software loads
2) I think you could either use the VWIC (or VWIC2) cards VWIC/VWIC2-MFT/2MFT-T1/E1, this should work on any 2800 series (or 1800 series) router depending on the card you choose. But be careful, sometimes in other countries, such as Mexico, the E1's don't arrive as an RJ-45, but as a coax and you need to go with an external DSU I believe.
Either that or the NM-1CE1T1-PRI if you choose a 2800 series that supports an NM card (ie: not the 2801).
pallavireddy. Tue, 05/15/2007 - 08:31
Hi Craig,
Thanks for ur quick response , much appreciated.
One last thing , which 1800 series are u using for HSRP???
Many Thanks,
imnilesh Wed, 05/16/2007 - 05:45
I am using 1841 on which HSRp work fine without any issue.....
Paolo Bevilacqua Tue, 05/15/2007 - 08:39
in reality you never need an external DSU when E1 is provisioned a coax. You just use the correct cable (CA-E1-BNC) and configure the card for unbalanced / 75 Ohm.
