Hyper Terminal Settings
May 15th, 2007
Could anyone tell me what setting i apply to Hyper Term so when i go and copy a Config back to a new switch or router it dosent miss all copyed text,my tutor told me about this setting but i forgot to write it down any help anybody.
Jon Marshall Tue, 05/15/2007 - 09:23
Hi Alex
I believe you need to increase the delay between sending lines in order not to overload the router.
I'm not at work at the moment so i can't remember exactly where it is but i think it is one of the settings you can change when you use the "transfer text" option.
Craig Norborg Tue, 05/15/2007 - 09:42
Under File/Properties/Settings in the ASCII setup tab, put in a "line delay" (maybe 10-50 milliseconds, you can play with it to tune it). Then you have to use "Send Text File" instead of pasting your config.
A much better way is to use TFTP to bring the config in. Just run a TFTP server and use a command like:
copy tftp:// running-config
and your changes will go in without a single mistake at all...
mohammedmahmoud Tue, 05/15/2007 - 10:49
I agree with Craig on his suggestions, and more to say is that if you can use telnet rather than console you won't face this problem.
Mohammed Mahmoud.
stonnet72 Tue, 05/15/2007 - 09:48
increase the buffer size on the destination (router or swithc). You should not have this problem anymore.
