Connection KIRK to Callmanager 4.2
May 15th, 2007
hi,
I'm testing the connection betwen CCM 4.2 and a KIRK Server IP1500. We configured the IP1500 Server like the Description from KIRK and also the callmanager. The Problem is, that the phones are connected to the DECT Server are not connected to the CCM.
Any suggestions?
Stephan
vmoopeung Mon, 05/21/2007 - 10:43
  • Bronze, 100 points or more
Check with region, codec , which protocol used SCCP, any trunk used to connect with the Servers.
Try with the gateway support, mostly it could be a codec mismatch.
