PIX 525 with high CPU utilization
May 15th, 2007
Have this issue that I need help with...
I have 2 525Pix's running 6.3(5) in failover...
The primary runs at a constant 60%-100% CPU usage and my inside and outside interfaces are running packet errors...
When show proc the only process' that is high is 557Poll, Pix/Inf1 and Pix/Inf3.
If I switch over to the standby the problem persists.
zubairjalal Tue, 05/15/2007 - 19:55
  • Bronze, 100 points or more
Is SNMP configured on the PIX and are you using any monitoring software which connects to the pix via SNMP. What kind of logging is setup on the pix.
marius_vt Tue, 05/15/2007 - 21:19
Thanks for the reply...
Nope no SNMP or any logging is done on the PIX ....It has been disabled..
