Brandon Buffin Tue, 05/15/2007 - 09:16
  • Purple, 4500 points or more
See the link below for the current equipment and IOS versions used in the lab.
http://www.cisco.com/web/learning/le3/ccie/rs/lab_equipment.html
Rather than trying to obtain all of the equipment yourself, you might consider using an online rack rental service such as Proctor Labs.
www.proctorlabs.com
Hope this helps. If so, please rate the post.
Brandon
mounir.mohamed Tue, 05/15/2007 - 11:26
  • Gold, 750 points or more
Dear sr2675402,
The minimum router series can be used in LAB prep. 2600 series.
Best Regards,
Mounir Mohamed
Wilson Samuel Wed, 05/16/2007 - 04:01
  • Community Spotlight Award,
    Mobile User, July 2015
If you do work for a Cisco Partner company then the best deals are always at the PEC.
cisco.com/go/pec
There are so many labs which are so good to enhance your skills on the tech that I simply loved that.
HTH,
Please rate if helpful.
Kind Regards,
Wilson Samuel
cisco.com/go/pec
