Unity Connection - Multi Language
May 15th, 2007
  • Community Spotlight Award,
    Member's Choice, May 2015
Unity Connection 1.2 - I've installed the UK English pack so now my system supports both UK/US english.
I've set the default language for the system to UK, and the users are set to UK.
However, if I go into any TUI bit to record a greeting I'm always prompted whether I wish to record for US or UK English - is it possible to disable US English so that this question isn't asked?
Aaron
Overall Rating: 5 (1 ratings)
lindborg Tue, 05/15/2007 - 13:48
  • Cisco Employee,
No, for each active language on the system (you can take US english out of the active list if you like) subscribers are given the option to record greetings for any of the languages - there's no way to have a list of languages that are installed and active for the TUI that are not offered for greeting recordings for subscribers.
Aaron Harrison Wed, 05/16/2007 - 04:36
Hi Jeff
OK - so how do I remove a language from the active list?
Thanks!
Aaron
Aaron Harrison Fri, 05/18/2007 - 07:43
Hi Jeff
Thanks!
Aaron
Aaron Harrison Tue, 05/22/2007 - 12:25
Anyone????
Ta
Aaron Harrison Thu, 05/24/2007 - 11:18
Please?
Aaron Harrison Thu, 06/07/2007 - 07:48
Ping
Aaron Harrison Fri, 06/08/2007 - 00:25
Ping
waynejackson Mon, 07/30/2007 - 22:59
I need to add a second language onto an existing unity connection install but can only locate the compelted install files via the download page- is there a language service pack and if so where can I obtain it it
thanks
