What all can be done with ASA5505-50-BUN-K9 ?
May 15th, 2007
We have bought ASA5505-50-BUN-K9.
We have more remote users that local network users. We would like to know
1. What's the maximum LAL-LAN IPsec VPN we can have with this bundle ?
2. How many remote users can simultaneously connect using a IPSec VPN client?
3. How many remote users can simultaneoulsy connect through web using SSL ?
4. Can multiple remote users simultaneously connect through web using the same SSL username/password ?
thanks in advance
Hi Reji
Hope this answers your questions, I am not to sure what you mean on number 4.
Maximum firewall throughput (Mbps) 150
Maximum 3DES/AES VPN throughput (Mbps) 100
Maximum site-to-site and remote access VPN ser sessions 10/25
Maximum SSL VPN user sessions 25
(Beginning with Cisco ASA Software v7.1, SSL VPN (Web VPN) capability requires a license. Systems include 2 SSL VPN users by default for evaluation and remote management purposes)
Regards MJ
dan.crabtree Thu, 05/17/2007 - 05:57
What I mean by question 4 is that if one user connects with one username/password, can another user in the same organization use the same username/password and connect simultaneously ?
ggilbert Thu, 05/17/2007 - 06:12
The default simultaneous logins on the ASA would 3. You can bump that up.
But, it would be best to use different username and password just for security reasons.
Hope this answers your question.
Rate this post, if it helps.
