Cisco switch not keeping VTP information on reload
May 15th, 2007
I am configuring a couple Cisco 2960G switches and for some reason, the VTP information (mode client/domain) doesn't stay in the configuration upon reload (after a copy run start of course). The switches aren't connected together, or to any other network, we're just boxing them and shipping after configs are done.
Is this supposed to happen? If anyone could clarify this for me, that would be great.
-Chris
Overall Rating: 5 (1 ratings)
ankbhasi Tue, 05/15/2007 - 10:15
  • Cisco Employee,
Hi Chris,
In VTP client mode, VLAN configurations are not saved in NVRAM. So what you are observing is an expected behavior.
In VTP server mode, VLAN configurations are saved in NVRAM.When the switch is in VTP transparent mode, the VTP and VLAN configurations are saved in NVRAM.
Ankur
*Pls rate all helpfull post
chris.lepa Tue, 05/15/2007 - 10:20
I know VLAN informatin isn't stored or configured while in client mode, but it doesn't save the VTP domain name or mode? It's weird... I also looked, and I don't seem to have a vlan.dat file in my flash directory.
chris.lepa Tue, 05/15/2007 - 10:22
Oh nevermind, I think I understand now. When I kept it in server mode and configured the domain, it stayed after reload. Thanks for you help, Ankur!
-Chris
Wilson Samuel Tue, 05/15/2007 - 10:33
  • Gold, 750 points or more
  • Community Spotlight Award,
    Mobile User, July 2015
Hi Chris,
Just a brief info, you may save the information also if you keep the VTP Mode Transparent.
HTH,
Wilson Samuel
